I use CW6.3 and PE3.09 for MCF51JM128.
i used [CW Plug-In IDE version 4.41.1] but now the IDW version is 4.41.
what is different between two version ?
how can i get version 4.41.1 PE.
I have some problem in IDE version 4.41, so I want to update to 4.41.1
does anybody konw this issue ?
BR/ Youngcheol
Solved! Go to Solution.
Hi Song.
PE plugin 4.41.1 has been used in service pack CW08_V6_3_CFV1_EM256_EM128_SP.exe.
install it to CW6.3 you can get PE IDE upgrade to 4.41.1.
Hope this helps!
Jennie Zhang
Hi Song.
Hope this helps!
Jennie Zhang
Hello Jennie,
Thank you for your help.
i could solve my problem according to your help.
BR / Youngcheol
Hi Song.
Can you please provide the CW install plug in information from your customer thus I will check it from my sdie:
Start the IDE and click on Help | About Freescale CodeWarrior. Click on Installed Products.Save all info displayed into a txt file and send it to me.
Thanks!
Jennie Zhang
