In the MMPF0100 One time programmability (OTP) is mentioned. Does that mean that we can configure the chip for only one time?
If so, do you have any other PMIC where I can configure power up and power down sequencing and change it as I want( more than one time)?
Bhavya
Hello Bhavya,
Thank you for writing.
The MMPF0100 has the TBB (Try Before Buy) feature. This means, you could program the fuses from the MMPF0100, before setting them a default value.
Here you have an application note, of how to program the MMPF0100 OTP registers.
http://www.nxp.com/assets/documents/data/en/application-notes/AN4536.pdf
I hope this information helps.
Diego.
