This selection seems to be missing from the Output drop down after a connection is added in the Properties tab of the Processor Expert component viewer. Is there a bug in the Processor Component or am I missing some prerequisite configuration? If its missing could anyone suggest the proper syntax for a PESL ConnectPin statement to connect PWMA_EXT_CLOCK/XBAR_OUT28 to TA0_OUT/XBAR_IN36.
