Background run error of NFC "DemoApp" on Raspberry pi for PN7120
sangdolee
We have OM5577 kit on Raspberry pi.
But, libnfc-nic.lib's sample application, "demoapp", seems not be running on background.
On the console, command "demoapp poll" is working well, but, command "demoapp poll&" is not working.
Call nfcManager_doInitiaize() function does not return.
Please help me.
I have run demoapp on backgound.
Paul
Kan_Li
Hi Sangdo,
I have tried that on Raspberry Pi 2 model B ver 1.1, it works well when running on background, did you install the correct image? Please kindly refer to the following for details.
Hope that helps,
B.R
Kan
