IPU Color video displayed in b/w
Question asked by Steven Guzior on Nov 1, 2016
Latest reply on Nov 6, 2016 by igorpadykov
We're trying to use an SCM-i.MX6DQ IPU synchronous display flow to output a video clip from Memory to an ADV7391 encoder.  The clip is YUV 4:2:2.
We've modified the Device Tree to output the 8-bit parallel interface and 27MHz clock.
Couple of issues:
1)  IDMAC channel 23 is enabled and displaying the console.  We want channel 23 to output the video only.
2)  IDMAC channel 27 is initialized when using v4l2 and displays the video, and is then overlayed onto Channel 23.
3)  Channel 27 output is black and white only.  (See attached video clips)  We are sending the first clip here:  YUV Sequences with "/unit_tests/mxc_v4l2_output.out -ih 144 -iw 176 akiyo_qcif.yuv"
The IDMAC channels follow this flow:
But we want this:
How do we configure the IDMAC channels to display properly when launching V4L2?  Is there a CPMEM configuration that needs to change?
*****CPMEM status for IDMAC channel 23****
--Word0@0x27005C0--
XV Virtual Coordinate[9:0]: 0000000000
YV Virtual Coordinate[18:10]: 000000000
YB inner Block Coordinate[31:19]: 0000000000000
XB inner Block Coordinate[43:32]: 000011110011
New Sub Block[44]: 0
Current Field[45]: 0
Scroll X counter[57:46]: 000000000000
Scroll Y counter[68:58]: 00000000000
Number of Scroll[78:69]: 0000000000
Scroll Delta X[85:79]: 0000000
Scroll Max[95:86]: 0000000000
Scrolling Configuration[96]: 0
Scrolling Enable[97]: 0
Scroll Delta Y[104:98]: 0000000
Scroll Horizontal Direction[105]: 0
Scroll Vertical Direction[106]: 0
Bits Per Pixel[109:107]: 011
Decode Address Select[111:110]: 00
Access Dimension[112]: 0
Scan Order[113]: 1
Band Mode[116:114]: 000
Block Mode[118:117]: 00
Rotation[119]: 0
Horizontal Flip[120]: 0
Vertical Flip[121]: 0
Threshold Enable[122]: 0
Conditional Access Polarity[123]: 0
Conditional Access Enable[124]: 0
Frame Width[137:125]: 0001011001111
Frame Height[149:138]: 000111100110
End of Line interrupt[150]: 0
--Word1@0x27005E0--
Ext Mem Buffer 0 Addr[28:0]: 00011100000100000000000000000
Ext Mem Buffer 1 Addr[57:29]: 00011100000100000000000000000
Interlace Offset[77:58]: 00000000000010110100
Number of Pixels in Whole Burst Access[84:78]: 0011111
Pixel Format Select[88:85]: 0111
Alpha Used[89]: 0
Alpha Channel Mapping[92:90]: 000
AXI Id[94:93]: 00
Threshold[101:95]: 0000000
Stride Line[115:102]: 00101100111111
Width0[118:116]: 100
Width1[121:119]: 101
Width2[124:122]: 100
Width3[127:125]: 111
Offset0[132:128]: 00000
Offset1[137:133]: 00101
Offset2[142:138]: 01011
Offset3[147:143]: 10000
Select SX SY Set[148]: 0
Conditional Read Enable[149]: 0
Decode Address Select bit[2][150]: 0
*****CPMEM status for IDMAC channel 27****
--Word0@0x27006C0--
XB inner Block Coordinate[43:32]: 000011110000
Scan Order[113]: 1
Rotation[119]: 0
Frame Height[149:138]: 000111011111
--Word1@0x27006E0--
Ext Mem Buffer 0 Addr[28:0]: 00011100101000000000000000000
Ext Mem Buffer 1 Addr[57:29]: 00011100101010101000110000000
Pixel Format Select[88:85]: 1010
Alpha Used[89]: 0
AXI Id[94:93]: 00
Width0[118:116]: 000
Width1[121:119]: 000
Width2[124:122]: 000
Width3[127:125]: 000
Offset1[137:133]: 00000
Offset2[142:138]: 00000
Offset3[147:143]: 00000
Thank you in advance!  Let me know if more information is needed.
