I’m try to doing the “bitbake fsl-image-test” for the Setup and Build the Community Yocto Project Dora BSP for Freescale i.MX6.
Encountered the error in the below image file.
Appreciate if you could advice how I can proceed from this error.
Thanks!
Hi Javier
as shows image1.png Ubuntu 16.04 was not validated with that version
of build system, recommended to try on tested Ubuntu 12.04 version and download
packages described in sect.3.1 Host packages attached Yocto Guide.
