Does 74AVC16T245 requires a pull up resistor
Question asked by Eddy ZHANG on Oct 28, 2016
Latest reply on Nov 3, 2016 by LPP
Hi Everyone,
I am need to a level shifter to convert 3.3V GPIO output from uC to 0.9V to interface with a shift register.
I am considering 74AVC16T245, However, This is no  detailed application notes on how to set it up.
My question is that does it chip require pull up/down resistor for each of its input channel?
if i only want 1 directional shifting, i can just tie the direction bit directly ground/Vdd correct?
Eddy
http://www.nxp.com/documents/data_sheet/74AVC16T245.pdf
