imx6ul bitbake fsl-image-mfgtool-initramfs fail
chunqiaohe
Hi all, i use the yocto project to build fsl-image-mfgtool-initramfs ,but there are some issues happen, please see the log as below. how to modify?
 thanks!
chunqiao@oneiotworld:~/fsl-release-bsp$ MACHINE=imx6ulevk source fsl-setup-release.sh -b imx6ulevk
Build directory is imx6ulevk
Welcome to Freescale Community BSP
The Yocto Project has extensive documentation about OE including a
reference manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
Your configuration files at imx6ulevk have not been touched.
chunqiao@oneiotworld:~/fsl-release-bsp/imx6ulevk$
chunqiao@oneiotworld:~/fsl-release-bsp/imx6ulevk$ bitbake fsl-image-mfgtool-initramfs
Traceback (most recent call last):
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/bin/bitbake", line 31, in <module>
import bb
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/__init__.py", line 77, in <module>
from bb import fetch2 as fetch
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 39, in <module>
from bb import data
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/data.py", line 48, in <module>
from bb import data_smart
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/data_smart.py", line 35, in <module>
import bb, bb.codeparser
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/codeparser.py", line 1, in <module>
import ast
ImportError: No module named ast
/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/event.py:111: RuntimeWarning: Parent module 'bb' not found while handling absolute import
from bb.msg import BBLogFormatter
Error in atexit._run_exitfuncs:
File "/opt/poky/1.8/sysroots/x86_64-pokysdk-linux/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/event.py", line 111, in print_ui_queue
from bb import data
import ast
Error in sys.exitfunc:
from bb import data
import ast
Labels (3)
Yuri
  Please check environment ; refer to section 3 (Host Setup) of
"i.MX_Yocto_Project_User's_Guide.pdf". First, please try to build core-image-minimal
image.
Yuri
Yuri
image.
Yuri
chunqiaohe
Hi Muhin:
     thanks for your replay. i follow the user's Guide to setup host environment. and try to build core-image-minimal first.
but there also have issue. please see  the log:
 form the log , you can see the error is "File "/home/chunqiao/fsl-release-bsp/sources/poky/bitbake/lib/bb/codeparser.py", line 1, in <module>
import ast
ImportError: No module named ast" .
i open the codeparser.py file,  the error is form here. but  how to change?
chunqiao@oneiotworld:~/fsl-release-bsp$ MACHINE=imx6ulevk source setup-environment imx6ulevk/
Common targets are:
core-image-minimal
meta-toolchain
meta-toolchain-sdk
adt-installer
meta-ide-support
Your configuration files at imx6ulevk/ have not been touched.
chunqiao@oneiotworld:~/fsl-release-bsp/imx6ulevk$ bitbake core-image-minimal
import bb
from bb import data
import ast
from bb import data
import ast
from bb import data
import ast
Yuri
    Perhaps it makes sense to use separate (clean) Linux (U-buntu, Debian) installation as Virtual Machine.
Yuri.
