Individual power consumption of each module of KEA-128?
vigneshbalaji
Senior Contributor I
     I am using KEA128 in my application and calculating power consumption of the micro-controller in different modes. For general GPIOs I can calculate power using pull-up pull-down value, but for other interfaces like UART, CAN, SPI, ADC I am unable to find data. I assume their consumption will be higher than other GPIOs. Please provide the data or guide me to right document for the same. Thanks.
miduo
Sorry we do not spec the power consumption for individual module. For customer who concern it, we recommend to calculate it by adding the RUN power consumption and each peripheral. You can find the consumption respectively from the datasheet.
vigneshbalaji
Hi Fang,
              I could not find the power consumption for individual module in KEA-128 in the datasheet?
If you post pics from the datasheet about this or give any alternate sources then it will be good?
