Hi there,
I use:
- CodeWarrior for MCU
Version: 10.6.4
Build Id:150416
with an
P&E Multilink Universal RevC Debugger.
Now i want to use the secure flash option.
If i download my firmware with via Debug or Run, all works fine. I get a notice that the device is secure and to unlock i need to erase. Works like a charm.
As soon as i try to program that lovely cpu with CodeWarriors integrated flash tool, i get an error (see attachment).
I use the same connection as in the run configuration. It does not make any difference if secure the firmware or not. Flash tools simply wont work!
Also i have not found out yet were CW does save the connection properties.
Any help would be welcome.
Kind Regards
Clemens
Original Attachment has been moved to: support1.txt.zip
Hello Clemens,
Cloud you please take a screenshot about the configure when you flash with " CodeWarriors integrated flash tool".
And whether it secured when you use the flash toll , so it can not write any registers .
Alice
The topic will be moved to CodeWarrior space as it concerns the integrated flash programming tool (not that much the MCU)
