LPC43xx EMC Buffer enabled
Question asked by sky sky on Oct 25, 2016
Latest reply on Nov 2, 2016 by sky sky
i use the lpc4353 EMC-CS0 driver the K9F1G08U0E nand flash.
when i set the register:Static Memory Configuration registers (STATICCONFIG[0:3],the bit 19
code is :
LPC_EMC->STATICCONFIG0 |= 1 << 19;
then,the chip K9F1G08U0E read/write error.
when i insert the delay() in the operation of K9F1G08U0E ,such as :
K9F1G08_CLE = K9FXX_READ_ID;
delay();
K9F1G08_ALE = 0;
delay();
a = K9F1G08_DATA;
delay();
b = K9F1G08_DATA;
delay();
c = K9F1G08_DATA;
delay();
the read/write is correct.
when i don't add code:LPC_EMC->STATICCONFIG0 |= 1 << 19;
the delay() is not need,the read/write is also correct.
