imx6dl.
kernel-3.14.52
gstreamer-1.8.1
gstreamer-imx-0.12.2
using:
v4l2src -> appsink (m_src->pushSample(sample)) // m_src = appsrc
appsrc->imxipuvideotransform->clockoverlay->imxvpuenc_h264->filesink
issue:
0:00:07.154376334 295 0xbac660 ERROR imxvpuapi imxvpuapi_vpulib.c:3299:imx_vpu_enc_get_initial_info: could not get initial info: failure
0:00:07.154445001 295 0xbac660 ERROR imxvpuencoderbase encoder_base.c:444:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> could not get initial
info: unspecified error
log detail:
0:00:05.393533001 295 0xb44400 INFO imxvpuencoderbase encoder_base.c:284:gst_imx_vpu_encoder_base_start:<imxvpuencoderh264-0> starting VPU encoder
0:00:05.393735001 295 0xb44400 LOG imxvpuapi imxvpuapi_vpulib.c:293:imx_vpu_load: VPU init instance counter: 0
0:00:06.071092668 295 0xb44400 INFO imxvpuapi imxvpuapi_vpulib.c:302:imx_vpu_load: libimxvpuapi version 0.10.1 vpulib backend
0:00:06.088824334 295 0xb44400 DEBUG imxvpuapi imxvpuapi_vpulib.c:306:imx_vpu_load: loaded VPU
0:00:07.101691001 295 0xb44400 INFO imxvpuallocator allocator.c:60:gst_imx_vpu_allocator_init:<GstImxVpuAllocator@0xb888d8> initializing IMX VPU decoder
allocator
0:00:07.101989001 295 0xb44400 TRACE imxvpuapi imxvpuapi_vpulib.c:475:default_dmabufalloc_allocate: allocated 32 byte, ptr: 0xdaf160
0:00:07.116604668 295 0xb44400 DEBUG imxvpuapi imxvpuapi_vpulib.c:499:default_dmabufalloc_allocate: allocated 1572864 bytes of physical memory
0:00:07.116889334 295 0xb44400 DEBUG imxvpuapi imxvpuapi_vpulib.c:509:default_dmabufalloc_allocate: retrieved virtual address for physical memory
0:00:07.117030334 295 0xb44400 DEBUG imxvpuapi imxvpuapi_vpulib.c:514:default_dmabufalloc_allocate: virtual address: 0x5da66000 aligned: 0x5da66000
0:00:07.117170001 295 0xb44400 DEBUG imxvpuapi imxvpuapi_vpulib.c:515:default_dmabufalloc_allocate: physical address: 0x45d00000 aligned: 0x45d00000
0:00:07.117313668 295 0xb44400 LOG imxvpuapi imxvpuapi_vpulib.c:293:imx_vpu_load: VPU init instance counter: 1
0:00:07.117483001 295 0xb44400 INFO imxvpuencoderbase encoder_base.c:310:gst_imx_vpu_encoder_base_start:<imxvpuencoderh264-0> VPU encoder started
0:00:07.140541001 295 0xbac660 INFO imxvpuencoderbase encoder_base.c:355:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> setting encoder format
0:00:07.140642334 295 0xbac660 DEBUG imxvpuencoderbase encoder_base.c:383:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> input format uses shared
chroma plane; enabling chroma interleave
0:00:07.140701001 295 0xbac660 INFO imxvpuencoderbase encoder_base.c:392:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> setting bitrate to 1000
kbps and GOP size to 16
0:00:07.150927001 295 0xbac660 INFO imxvpuenc_h264 encoder_h264.c:234:gst_imx_vpu_encoder_h264_set_open_params:<imxvpuencoderh264-0> produce h.264 access
units: yes
0:00:07.151153001 295 0xbac660 TRACE imxvpuapi imxvpuapi_vpulib.c:2881:imx_vpu_enc_open: allocated 2100 byte, ptr: 0x65a16800
0:00:07.151275668 295 0xbac660 LOG imxvpuapi imxvpuapi_vpulib.c:3061:imx_vpu_enc_open: opening encoder, frame size: 720 x 576 pixel
[INFO] ringBufferEnable 0, chromaInterleave 1, mapType 0, linear2TiledEnable 1
0:00:07.153872001 295 0xbac660 DEBUG imxvpuapi imxvpuapi_vpulib.c:3078:imx_vpu_enc_open: successfully opened encoder
0:00:07.153955668 295 0xbac660 TRACE imxvpuencoderbase encoder_base.c:429:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> configuring encoder
0:00:07.154167001 295 0xbac660 TRACE imxvpuencoderbase encoder_base.c:440:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> retrieving initial info
[WARN] VPU iram is less than needed, some parts don't use iram
0:00:07.487521001 295 0xbac660 WARN videoencoder gstvideoencoder.c:674:gst_video_encoder_setcaps:<imxvpuencoderh264-0> rejected caps video/x-raw,
width=(int)720, height=(int)576, framerate=(fraction)1/25, interlace-mode=(string)progressive, format=(string)NV12
0:00:07.488277668 295 0xbac660 INFO imxvpuencoderbase encoder_base.c:355:gst_imx_vpu_encoder_base_set_format:<imxvpuencoderh264-0> setting encoder format
0:00:07.488351001 295 0xbac660 DEBUG imxvpuencoderbase encoder_base.c:797:gst_imx_vpu_encoder_base_close:<imxvpuencoderh264-0> closing encoder
0:00:07.488399001 295 0xbac660 DEBUG imxvpuapi imxvpuapi_vpulib.c:3099:imx_vpu_enc_close: closing encoder
0:00:07.488586668 295 0xbac660 TRACE imxvpuapi imxvpuapi_vpulib.c:3125:imx_vpu_enc_close: freed 2100 byte, ptr: 0x65a16800
0:0
