Conncerning sensors MPX5010, MPX5050, MPX5100: Disintegtration pressure
Question asked by Alexander Steingass on Oct 24, 2016
Latest reply on Oct 25, 2016 by Diego Adrian Cuevas
Conncerning sensors MPX5010, MPX5050, MPX5100: If I connect for a test the two sensor inputs together, the electric output of the sensor should be zero. What is the maximum pressure that can be applied to this common input against surrounding pressure before the sensor disintegrates? In the data sheet I have only found the maximum dipperential pressure.
Can I connect the inputs to water? If not, what would be an alternative sensor?
