Using a LPC4357 I am trying to configure P9_3 to have MCOA0 function.
If I write to the configuration register 0x40086000+0x49C it seems to have no effect I read back all zeros, but if I do the same for another pin (0x40086494) the change takes effect and I read back the correct value.
What can cause this behavior?
Hi Customer,
Thank you very much for your detail information.
I think your problem is caused by the LPC4357 user manual error.
I check it again, I have found the address for SFSP9_3 is 0x40086000+0X48C, not like the document mentioned 0X49C, actually 0X49C is reserved:
I have do the testing on my MCB1758 with LPCXpresso IDE, the debug interface also shows the address for P9_3 is 0x4008648c.
So, please change the P9_3 address to 0x4008648c.
I will report this document to our according department immediately, the problem will be fixed in the next doc reversion.
Thanks a lot for your good question and sorry for the inconvenience we bring you.
Kerry
