linux kernel crash dump surpport in linux4.1.15 for imx6
xinchangxiang
Hi All,
       I want to dump crash file in file system, such as LKCD .
       If anyone knows about this , can you please give the references
Bio_TICFSL
Although many debugging tools claim that they could support ARM architecture such as KDUMP, LKDC Crash Uitlity,etc, they are unstable. I just can suggest to try: Kernel/KernelDebuggingTricks - Ubuntu Wiki  in case of i.mx6 debug kernel.
  Or you should try to Build Linux Kernel and make sure that the feature kexec and debug info are enable.
·         Boot options  —>
·         [*] Kexec system call (EXPERIMENTAL)
Kernel hacking  —>
·         [*] Compile the kernel with debug info
xinchangxiang
Thanks for your help , I have a try.
