I need build my application for S12VR48 with a makefile project. Hence, i extended the sample MakeFileSample_HC12 from "CWS12v5.2/(CodeWarrior_Examples)" direction.
Now, i extended the sample complete. I can use rebuild command successful, but can't use build command.
It report error as following:
Reading make file 'F:\Workspace\trunk\Skylight\Project\makefile.mak' F:\Workspace\trunk\Skylight\Project\makefile.mak: ERROR M5022: Don't know how to make "etimer.s" F:\Workspace\trunk\Skylight\Project\makefile.mak: ERROR M5022: Don't know how to make "etimer.o" F:\Workspace\trunk\Skylight\Project\makefile.mak: ERROR M5022: Don't know how to make "Project.abs" F:\Workspace\trunk\Skylight\Project\makefile.mak: ERROR M5022: Don't know how to make "all" F:\Workspace\trunk\Skylight\Project\makefile.mak: ERROR M5022: Don't know how to make "all"
Here is my makefile:
############################## Auto-make file: default.mak############################## Following variables should be updated to reflect you current project settings.# PROJECT: Project name. Name of the final absolute/S19/library file,# without path informationPROJECT=Project # SOURCE_FILES: All C/C++/ASM files (without path)SOURCE_FILES=datapage.c Start12.c main.c mc9s12vr48.c clock.c etimer.c process.c stimer.c timer.c Hal.c Hil.c Anti-pinch.c Diagnose.c SafeRank.c MotorClass.c Debug.c Motor.c Operation.c RealtmSt.c Skylight.c # ADD_OBJECTS: Additional object/library files to link withADD_OBJECTS=ansisf.lib # INSTALLPATH: Path where tools are installed (root installation# directory). If called from build.bat, INSTALLPATH# is through -D option.# Remove comment below and adjust path if INSTALLPATH is not# set on make invocation line#INSTALLPATH=C:\Freescale\CodeWarrior_HC12# LINKFILE: Linker parameter file to be usedLINKFILE=.\prm\project.prm# MAKEFILE: Name of this make fileMAKEFILE=makefile.mak # define here if you want to build a absolute file (abs) or a library (lib)BUILD_TARGET_EXT=abs#BUILD_TARGET_EXT=lib#INCLUDEPATH: Paths where application or system include files can be# found.INCLUDEPATH="$(INSTALLPATH)\lib\hc12c\include"#".\Sources\user\arch";#".\Sources";#".\Sources\user\bsw";".\Sources\user\module";".\Sources\user\oop";".\Sources\user\task";#"F:\Workspace\trunk\SharedCode\contiki-3.0";"F:\Workspace\trunk\SharedCode\contiki-3.0\sys"#GENPATH: Paths where application source and prm files can be# foundGENPATH=.\Sources;$(INSTALLPATH)\lib\hc12c\src;$(INSTALLPATH)\lib\hc12c\include;$(INSTALLPATH)\lib\hc12c\lib;.\Sources\user\arch;.\Sources\user\bsw;.\Sources\user\module;.\Sources\user\oop;.\Sources\user\task;F:\Workspace\trunk\SharedCode\contiki-3.0;F:\Workspace\trunk\SharedCode\contiki-3.0\sys; #OBJPATH: Path where compiler and assembler will place object filesOBJPATH=.\bin#ABSPATH: Path where linker will place executable fileABSPATH=.\bin#TEXTPATH: Path where linker will place map file and compiler# disassembly listing file and dependency file.TEXTPATH=.\bin # The name of the dependency list file. Here the compiler itself updates the# make file!DEP_LIST_FILE=$(PROJECT).dep #ENVOPTIONS: Command line options to set environment variables.ENVOPTIONS=-ENV"GENPATH=$(GENPATH)" -ENV"OBJPATH=$(OBJPATH)" \ -ENV"ABSPATH=$(ABSPATH)" -ENV"TEXTPATH=$(TEXTPATH)"# Here there are some special options to select the object file format for# compiler/assembler/linkerCC_OBJ_FORMAT=-F2 AA_OBJ_FORMAT=-F2 LL_OBJ_FORMAT=-Fe # Compiler settings, C and C++ options.# Short description about the options used (you may adapt this options to your# own need):# -Lasm: Produce listing file# -Lm: Generate dependency information# -LmCfg: Configuration options for -Lm: m=write path of main file, i=write# path of included files, u=update information# -D: Add preprocessor define, here it defines the target derivative name# -WmsgFob: Option to configure the message output format. Here we changed the# format so that the column number is written too# -C++f: Use full C++ mode for C++ filesCC=$(INSTALLPATH)\prog\cHC12.exe CCFLAGS_COMMON= $(CC_OBJ_FORMAT) -Lasm -Lm=$(DEP_LIST_FILE) -WmsgNu=abcet \ -I$(INCLUDEPATH) -LmCfg=ilmu $(ENVOPTIONS) CCFLAGS=$(CCFLAGS_COMMON) -CpuHCS12 -DPPAGE_ADDR=0x15 -Ms -Cf CPPFLAGS= $(CCFLAGS_COMMON) -C++f # Assembler settings# Short description about the options used (you may adapt this options to your# own need):AA=$(INSTALLPATH)\prog\aHC12.exe $(AA_OBJ_FORMAT) -WmsgNu=abcet $(ENVOPTIONS) AAFLAGS= -CpuHCS12 -Ms # linker settings# Short description about the options used (you may adapt this options to your# own need):# -M: Generate map file (overwrites the optional MAPFILE command in the# linker parameter file# -O: Name of the output file. Overwrites the optional one specified in the# linker parameter file# -Add: The list of object/library files specified here is linked to the# application (together with the ones specified in the linker parameter# file)LL=$(INSTALLPATH)\prog\linker.exe LLFLAGS= -M -O$(PROJECT).abs -WmsgNu=abcet -Add($(ALL_OBJ_FILES) $(ADD_OBJECTS)) \ $(LL_OBJ_FORMAT) $(ENVOPTIONS) # burner settings, only used for S-Record, Intel HEX or binary output files# Short description about the options used (you may adapt this options to your# own need):# OPENFILE: Creates/opens the destination file# format: Format of the file, here it is motorola S-Record# origin: Start address from where to copy, here begin of memory (address zero)# len: Set to maximum, that is the whole application# busWidth: Set to one, thus no splitting between different eeproms# SENDBYTE: Starts generation of the outputBB=$(INSTALLPATH)\prog\burner.exe BBFLAGS= $(ENVOPTIONS) \ OPENFILE "$(PROJECT).s19" \ format = motorola \ origin = 0x0000 \ len = 0xffffffff \ busWidth = 1 \ SENDBYTE 1 "$(PROJECT).abs"# libmaker settings, only used for libraries# Short description about the options used (you may adapt this options to your# own need):LM=$(INSTALLPATH)\prog\libmaker.exe LMFLAGS= $(ENVOPTIONS) -NoPath -Cmd"$(ALL_OBJ_FILES) $(ADD_OBJECTS) = $(PROJECT).lib"################################################################################### from here you don't need to adapt the automake file################################################################################### build object file list with search and replace operationCPP_OBJ_FILES = $(SOURCE_FILES:.cpp=.o) CXX_OBJ_FILES = $(CPP_OBJ_FILES:.cxx=.o) C_OBJ_FILES = $(CXX_OBJ_FILES:.c=.o) S_OBJ_FILES = $(C_OBJ_FILES:.s=.o) ALL_OBJ_FILES = $(S_OBJ_FILES:.asm=.o) ###################################### rules###################################### top targetall: $(PROJECT).$(BUILD_TARGET_EXT) echo *** $(PROJECT) is up to date. *** # this targets enforces a rebuild:# 1) delete the dependency info file (may contain outdated information)# 2) call a second maker process to build the target again, with following options:# $(MAKEFILE): Make file, which is this file# -Prod: Project file with all other settings# -WmsgVrb: Use verbose mode, so we know what is going on# -D: Pass through macro variables we got from the invocation line# directly (INSTALLPATH)# -ViewMin: Run as iconified application# -Mkall: Make the target without checking for dependency datesrebuild: -del $(DEP_LIST_FILE) -del $(TEXTPATH)\$(DEP_LIST_FILE) $(INSTALLPATH)\prog\maker.exe $(MAKEFILE) $(ENVOPTIONS) -WmsgVrb \ -D(INSTALLPATH=$(INSTALLPATH)) -ViewMin -mkall echo "*** rebuild done ***" $(PROJECT).abs: $(LINKFILE) $(MAKEFILE) $(ALL_OBJ_FILES) $(ADD_OBJECTS) $(LL) $(LLFLAGS) $(LINKFILE) $(BB) $(BBFLAGS) $(PROJECT).lib: $(MAKEFILE) $(ALL_OBJ_FILES) $(ADD_OBJECTS) $(LM) $(LMFLAGS) # various rules how to build an object file from a source file.c.o: $(CC) $(CCFLAGS) $*.c .cpp.o: $(CC) $(CPPFLAGS) $*.cpp .cxx.o: $(CC) $(CPPFLAGS) $*.cxx .asm.o: $(AA) $(AAFLAGS) $*.asm .s.o: $(AA) $(AAFLAGS) $*.s ########################################################dependency section, generated/updated by the compiler####################################################### INCLUDE $(DEP_LIST_FILE)
can anyone help on this ?
thanks,
Pamis
Solved! Go to Solution.
...I find the reason. I haven't revise the GENPATH variable in build.bat file.
