Question of the changing endian
Question asked by Luke Chun Employee on Oct 20, 2016
Latest reply on Oct 23, 2016 by Luke Chun
Hello Team
Could you check my question about MPC5676R?
How to change the endian between big endian and little endian?
As my checking, it can change by MAS2’s E(0 bit) bits.
In case of big endian, it should be 0.
In case of little endian, it should be 1.
and other way,
It looks like that is possible to change by CW2.10’s Setting.
If it changes “Byte ordering” on EPPC target..
However when I tried to use above ways, it makes the error..and I cannot find how to fix it..
Could you provide the way of change the endian between big endian and little endian for MPC5676R?
Thank you.
