LPUART on KL17Z support Ring buffer (FIFO) ?
mr_max
I cannot find clear information about that :
Does LPUART peripheral on KL17Z256VLH4 support Ring buffer (FIFO) ?
The MKL17Z4_features.h file set by default FIFO to 0
#define FSL_FEATURE_LPUART_HAS_FIFO (0)
Setting this feature to 1 generate error in compilation
../drivers/fsl_lpuart.h:153:32: error: 'LPUART_FIFO_RXEMPT_MASK' undeclared here (not in a function)
So I guess that KL17Z does not support it but I want to be sure.
kerryzhou
Hi Maxime Dolberg,
    Yes, your suppose is correct.
   KL17Z256VLH4  doesn't have the FIFO, it just has the data buffer, so the KSDK set the fifo to 0.
Wish it helps you!
If you still have question, please contact me!
Kerry
mr_max
Ok I see. Thank you.
