We are looking to make sure the pin-pin compatibility in i.MX7S Rev A, Rev B and Rev C.
Can you please share me the errata, where it captures the modification done in revision?(Like any pin configuration change or other modification done in revision)
Quick response will be highly appreciated.
Hi Bimal
please check
http://cache.freescale.com/files/shared/doc/pcn/PCN16558.htm
Hi Igor,
Thanks for sharing,
The shared link seems for i.MX6D and S, Can you share for i.MX7S?
Hi Bimal
sorry for confusion I mislooked that, i.MX7 part number decoder is
given in Figure 1. Part number nomenclature—
i.MX 7Dual family of processors i.MX7D Datasheet
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX7DCEC.pdf
Rev.1.2 is production part, its errata is given in i.MX7 Errata
http://cache.nxp.com/files/32bit/doc/errata/IMX7D_2N09P.pdf
Rev.1.0,1.1 are preproduction parts, its data is not publicly available
and may require nda with nxp. Recommended to create service request
for obtaining more details.
How to create service request :
https://community.freescale.com/docs/DOC-329745
