Hi guys, there is a way to debug an hcs12 using a FRDM-K22 as debugger?
silviovallorani
I need to read and write flash memory and eeprom of an HCS12 micro and I have a FRDM-K22.
I know there is a USBDM fw version running on OpenSDA v2.1 which can debug kinetis arm microcontrollers via SWD; I hope there is a way to implement also the BDM firmware on it.
Thank you for your help.
Tags (2)
