How to copy data from controller to USB?
vigneshkumarp
Hi, I'm using my own board of MK20DX128VLF5. Here we need to copy the data from flash memory to the USB pen drive when it is inserted. The copied data is going to be save as .xlsx format. We just want some example code to implement the above concept(copying the data from flash to pen drive in .xlsx format ). Is there any source code and relevant document available for USB programming?
MarMiAmit_KumarpavelrechDavidSkubanbvicentegomezramakrishnanidmartykhumphriMandar‌Deactivated user‌
isaacavila
This document can guide you to create a new USB Host MSD Project (on Processor Expert) which also adds support for FatFs: https://community.nxp.com/docs/DOC-331376
Saving data in .xlsx format is not handled in this document, but you can start with a basic USB Host MSD + Fatfs example.
I hope this can help you!
Isaac
