Do you know if MQX have been already used to pass DO-178D certification ?
Thanks in advance,
BR,
Philippe. NXP CAS
Hi phil74:
Even if your application does no require formal certification, the robustness of the MQX RTOS helps provide a rock-solid platform proven in thousands of time-critical, sophisticated applications
For those who must follow a formal certification process, the MQX RTOS platform has a record of past certification in medical specifications and the aerospace requirements listed under DO-178B. Safety critical applications based on MQX RTOS include eye surgery equipment, drug injection equipment, radiation dose monitoring equipment, aircraft braking system and aircraft navigation equipment.
If you need help for certification, the original author of MQX, Embedded Access, may be able to help.
