Software decoding can use video render acceleration?
fdact
    The api allocateOutputBuffersFromNativeWindow can allocate buffer for vpu, so can I use the api for software decoding?
Thanks.
Hi ferdinand
VPU APIs were intended for use with VPU usage only and were not
tested for others purposes. You can try to test and if works, use on own risk.
