sensor type MPXH6300A
philk
for sensor type MPXH6300A is there an option for a more media resistant gel ? current device has a florosilicone type gel
TomasVaverka
Hi Phil,
No, there is not. There are only the MPXHZ6250A and MPXHZ6400A series available with the media resistant gel.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
philk
Tomas,  In the "as received" condition there are a mix of cloudy and the clear gel on the same reel....does the cloudy appearance impact performance or is this an acceptable condition ?
TomasVaverka
Hi Phil,
Tomas
