Hi there,
I was having issues installing the neard explorenfc proprietary nxp software, even though i've tried several time to make it work properly, and it even seems that the board is not recognised, like it's not connected (the SPI is already turned on). Any idea on how to solve this?
Thanks Sincerely,
Mario
Hi Mario,
Since your issue happened during removing and installing the neard explorenfc package, I recommend you installing a full version of "Jessie" image and check if it makes any difference.
Wish it helps.
Kan Li
Hi Mario,
Are you using Raspberry Pi with the EXPLORE-NFC board? If yes, Please kindly check if you are using Raspberry Pi Model B or B+ or Raspberry Pi 2/3, and if the Raspbian “Jessie” image is downloaded correctly, please kindly refer to http://cache.nxp.com/documents/application_note/AN11480.pdf?fsrch=1&sr=3&pageNum=1 for more details.
Wish it helps.
Kan Li
