When the MKE1x family will be supported by the clock tools?
Jack_
Helo,
I installed the v2.0 of KE tools but the devices I use are not supported.  I've been testing and there are very few devices supported.
I am very interested in this software because this family of devices is not supported by  Processor Expert.
A list of supported devices will be useful.
Thank you,
Joan
BlackNight
Hi Joan,
the clocks tool is depending on the Kinetis SDK V2 API, so there has to be SDK support for the KE1x first which is currently not supported by the SDK. Maybe that question is more for the article in https://community.nxp.com/docs/DOC-329783  which has a roadmap (I already have asked to get it updated).
I hope this helps,
Erich
Jack_
Hi Erich,
Thanks for the answer, but the KE1x  is already supported by the latest version of the SDK. I have created projects using KDS3.2.0 using SDK2.0.
I used the tool to configure the pins but it would be very useful to have a tool to configure the clocks due to the system complexity.
Joan
BlackNight
Hi Joan,
ah, I see, I was looking in the wrong place. I'll try to find out when the KE1x will show up. You should not need new tools, as it will fetch the new data from the server.
Erich
Jack_
Hi Erich,
I wait for news about improving the system.
Thank you very much,
Joan
