How to use shutdown selftest--(MPC5744P)
xiaobozheng
when we running shutdown selftest function and finished ,the main chip will reset, but it will jump to wrong address,not form start address , so is there any MPC5744P shutdown selftest example?
   thanks
petervlna
What do you mean by wrong address?
Is that address bootable?
Could you specify your issue closely?
Peter
davidtosenovjan
I am afraid we probably currently do not have such example.
However have you read following section in device’s RM?
70.6.3.1 Preparation before initiating an STCU shutdown self-test
I am asking because there is quite enough amount of preconditions needed to be fulfilled before shutdown self-test execution.
