No UART output coming from USB stick JN5169
louiscroisez
i have recompiled the ZigBee coordinator.
The button switch device is able to communicate with the 3-LED light device, so the coordinator is basically working.
But I just do not see any debug traces on my terminal.
I am using UART0 (the one configured by default in the sources).
mario_castaneda
Hi Luois,
What is the application note that you took as a reference? Are you using the USB dongle?
Best Regards
Mario
