Hello Team,
I am using QorIQ SDK1.7 to deploy Hypervisor on T1040 RDB board.
I am getting following details from the SDK pdf.
Use the mux_server to connnect to the board to ensure that individual UART streams are
decoded correctly on the host side.
./mux_server "/dev/ttySx"<port number 1> <port number 2> <port number 3> &
socat -,raw,echo=0 tcp:0:<port number 1>
socat -,raw,echo=0 tcp:0:<port number 2>
socat -,raw,echo=0 tcp:0:<port number3>
But when I tried to use mux_server command on ubuntu14.04 I am getting error "mux_server" command not found.
How to install mux_server on Ubuntu14.04.
Thanks.
Solved! Go to Solution.
You can find it at the following URL:
sdk/hypervisor/mux_server.git - Hypervisor byte-channel de-multiplexer
Clone it; compile it on your machine then you can use the binary.
