Can someone suggest a reference material for JN5169 to achieve functionality mentioned below?
Using following SDK as a starting point.
Hi Nisarg,
You can take a look the next application notes.
ZigBee Home Automation|NXP The app note JN-AN-1223
Also the JN-AN-1184 could help you with the Zigbee Coordinator.
The App note provides the documentation for each example.
Hope it helps.
Mario
