I am using Android 5.0 BSP to test Bluetooth . WG7831-D0 Wi-Fi BT Combo module from Jorjin is being used . When I test the OPP from remote phone to the host , the file transfer is success . But when I try to send the file from the host to the phone, the transfer fails. The phone is not even getting the " Accept the file" prompt. Later the host hangs and the kernel crashes and reboots.
Has anyone experienced the same issue?
Thanks & Regards,
Anjali
