modify the ip address during running
Question asked by nine sun on Oct 9, 2016
Latest reply on Oct 17, 2016 by Iva Susnova
Can I modify the ip address when socket task is running. for example. I had used function ipcfg_bind_staticip to set ip address at first then i build the socket task. If i receive any modify ip command(etc from serial port or network), Can I modify the IP addres use the ipcfg_bind_staticip with new ip address? Can anyone give some suggestion? thanks
