The Video will Beat when Play test.264
rothwanhuang
hi ,My BSP is Imx6q_L3_14_52,and video is from camera sensor. I use VPU to encode encode 720x480 raw YUV video to test.264.and developing one of my own encoding application I tried to encode this raw video using 'mxc_vpu_test' application.
For that I used following command:
./mxc_vpu_test.out -D "-i  test.264 -f 2  -u 1  -w 720 -h 480"
But the video of display will beat,The attachment is the test.264 , you can use VLC to play it.What is the problem ? and how  to slove the problem?
Thanks!
Original Attachment has been moved to: test.rar
rothwanhuang
yes,the same result,thanks!
joanxie
my vlc player couldn't play the test.264, do you  mean you get the same result whatever you use ./mxc_vpu_test.out -D or vlc player?
