we bought the PNEV533D eval board and would like to download the respective documentation, i.e. full data sheet, app notes, Win7 software.
The docs and the eval board software seems to be restricted.
I tried to send a filled out NDA to the mentioned fax number: no answer. Also the email stated in the NDA form is not valid.
So is there an easy and fast way to get the a.m documents and software so that we can start work on the PNE5331 and the PNEV533D eval board?
Thanks.
Roland
Hi Roland,
Please kindly contact your local DFAE for help on this issue. You may refer to Distributor Network|NXP for more details.
Wish it helps.
Kan Li
This kind of closed answer on an open forum discourages me from pursuing NXP as a partner. Disappointing.
Hi Mark,
The NDA related issues should be handled with the help of your local DFAE, as they know the channel to some local sales. Sorry for the inconvenience that has caused and thanks for your understanding!
Kan
