USB driver for MK66 MCU (USB-HS device mode)
Question asked by Edwin kaus on Oct 4, 2016
Latest reply on Oct 25, 2016 by isaacavila
I am working on MK66FN2M0VLQ18 MCU in customized board.
I need to enumerate the MCU in USB device mode, I am using SDK_2.0_MK66FNM0xxx18 stack , in that if I use USB_DEVICE_CDC_VCOM the device is enumerated as virtual com port device.
>> Can I achieve 480Mbps(USB-HS) as com Port device.
Or Is there any example to enumerate device as normal Bulk USB device in that I need only control end point, Bulk IN and Bulk OUT endpoint.
