Supply voltage for read operation
Question asked by Casella Roberto on Oct 3, 2016
Latest reply on Oct 10, 2016 by vicentegomez
I'm using an MC9S08LC60 HCS08 family device. I found the following specification about supply voltage for read operation:
0 < Fbus < 8MHz           ----     Vread 1,8 to 3,6V
0 < Fbus < 20MHz         ----     Vread 2,08 to 3,6V
Where is the difference? If I use an 8Mhz external resonator to obtain an internal 2Mhz bus clock which voltage range must  I consider?
Thank you
