MPC5604E MJPEG Circular Buffer Issue
suhass
I have connected the parallel Video data lines of MPC5604E to the Digitizer and I am getting data through it, Configuration of MJPEG encoder has been done, JPEGIn Config stream is fed, and MJPEG encoder is switched on, on doing so circular output buffer is being filled with data once, and not getting refreshed. So how to validate the integrity/correctness of  the encoded data?
We are not accessing the output buffer right now, but we are checking it through debugger.
Tags (2)
lukaszadrapa
data in the circular buffer are continuously overwritten, there must be some error in your configuration.
Lukas
lukaszadrapa
check the Status_config register to see the settings of video encoder wrapper. Then use some test patterns of the camera and check the received data using subchannel reception.
Lukas
suhass
Hey,
Thanks for the reply, Lukas.
But my main question remains unanswered, i.e. Circular buffer is getting filled once, and data is not getting refreshed as camera is being streamed continuously.
As it is a circular output buffer it must refresh and rewrite itself continuously. Correct me if I am wrong.
Thanks & Regards
SUHAS S
lukaszadrapa
Lukas
