I have K60 Towerboard, _K60P144M150SF3RM, with MQX4.2, and CodeWarrior 10.6.4.
In Code Warrior project property page for generating SREC hex file as shown:
How do I control the srec line length?
The default is 45 chars length:
S21401F4B080809090909090808080808080808080F6
Is anyway to make it longer?
Thank you,
David Zhou
Solved! Go to Solution.
Hi David,
see https://mcuoneclipse.com/2013/10/29/s-record-manipulation-with-gnu-objcopy-and-burner-utility/ .
Otherwise I'm using the open source SRecord utility for advanced manipulations, see https://mcuoneclipse.com/2015/04/26/crc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse/ and https://mcuoneclipse.com/2015/09/23/aligning-s19-records-to-64-bit-boundaries/ .
I hope this helps,
Erich
Hi David,
I hope this helps,
Erich
Thanks, Erich.
David
