MFGTool Error while flashing Mars Board
kunalkulshresth
I am facing issues while trying to flash Mars Board with linux image. I use mfgtool after connecting to board with ogt cable. mfgtool very well recognises the HID compliant device, and start loading but stucks at updater "Jumping to OS". What could be possible things I am missing here? Mfgtool says "mx6q linux update". Also, before doing this, I used imx_usb_loader to flash u-boot into the mars board, but could not see anything on serial terminal so planned to flash it using mfgtool.
Any help to flash the Mars board will be good. Please let me know if more info is required.
Thanks and regards,
KK
Tags (3)
