Hello
I use ZigBee Pro stack and JN5168 module.
How can I read Neighbour table and Routing table on local node?
I believe you can read the neighbor table of the local node using the ZPS_eAplZdpMgmtLqiRequest function (just set the destination address to that of the local node).
