Recently I bought imx6qp sabre ai board and want to connect the muRata's Wi-Fi Bluetooth module.
I have problem in connecting the Base board(MCIMXABASEV1) and the Wi-Fi BT module(LBEH5DU1BW-TEMP-DS-SD). Help me to connect them. Also help how to use and test. And I am using yocto platform to build the image , used the fsl-bsp-release for building the image.
Lavakumar S
