jie xiao
How to use full stop mode(xep100)
Discussion created by jie xiao on Sep 26, 2016
Latest reply on Sep 27, 2016 by iggi
I tried to use full sleep mode while found this in datasheet:
"The system stop modes are entered if the CPU executes the STOP instruction unless either the XGATE is
active or an NVM command is active. "
What is "the STOP instruction"?
What should i do except setting  PSTP to zero?
