Ashley Duncan
Random Hard Faults
Discussion created by Ashley Duncan on Sep 25, 2016
Latest reply on Oct 11, 2016 by Ashley Duncan
I have a very frustrating and odd issue.  Since I have been using the Kinetis K22F dev kit with onboard open SDA debugger (changed to PE code) I have been getting some strange behavior.  Every now and then the micro has a hard fault for no obvious reason.  Most of the time when it happens doing a remove all break points seems to solve the problem.
Anybody know how to prevent this.  Usually happens when you edit code and it loses track of correct break point locations.
Ashley
