Hi I am working with s32v234 board, I would like to know if S32 design studio is compatible with this board for compiling and debugging?
sruthikilari
If s32 design studio is not compatible, could you please suggest some other compiler/debugger to work with s32v234?
martin_kovar
yes, S32 Design Studio for ARM supports S32v234. You will be able to compile and also debug projects for this microcontroller.
If you have any other questions, please feel free to write me back.
Martin
sivatejareddyva
hi,
i am trying to run a simple printf statement in the above mentioned for(;;) loop. But i am facing make:***[maker.elf] Error 1. Can i get some help??
