MFRC631
MFRC631
colinzou
Send the packet will be lost 1 byte
weidong_sun
  I couldn't confirm how you knew 1 byte had been lost, if you found data recieved lost 1 byte, Possible reason is that signal of the receiving end is weaker than noraml , So SNR is smaller, you can refter to antenna document to debug it. see the link:
High-performance multi-protocol NFC frontend|NXP
·      CLRC663, MFRC630, MFRC631, SLRC610 Antenna Design Guide (REV 1.3)
·       PDF
·      (2.2 MB)
·      AN11019
·      [English]
12 May 2016
Weidong
