imx6q MII RGMII
imx6q MII RGMII
eliaz
Can the imx6q use RGMII & MII peripheries  in the same time (Can these peripheries be active in the same time)?
Labels (2)
eliaz
can you be more specific about multiplexing , which signal is shared between the interfaces?
Yuri
 IMX6Q has ENET module, which supports MII, RMII, RGMII interfaces
Pins affected are described in Table 23-1 (ENET External Signals) of
the i.MX6 RM (Rev. 3, 07/2015). Only single interface may be used
at a time because of multiplexing.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
eliaz
eliaz
