I have K60 Tower board:_K60P144M150SF3RM , MQX 4.2, CodeWarrior v10.6.4
I have my project built as release. I found there are a lot of debug strings are included into the .elf binary file.
.debug_str 0x0000ced5 0x8f C:/Freescale/CW MCU v10.6.4/MCU/ARM_GCC_Support/ewl/lib/armv7e-m/fpu\librt.a(ROMCopy.o)
.debug_frame 0x00000000 0x5e40
.debug_frame 0x00000000 0xe4 ./Sources/MSxUart.o
.debug_frame 0x000000e4 0x15c ./Sources/MSxSwap.o
and when I examine the elf file, there are a lot of strings appended at the end of elf file. I want to limit the size of binary, how do I exclude any unnecessary debug data, debug string, and debug frames, etc from the binary file?
Thank you,
David Zhou
Solved! Go to Solution.
Sorry, it is in .elf, not binary file.
Case closed.
Thank you,
David Zhou
Case closed.
Thank you,
David Zhou
