Dear all,
We run Android M6.0 on SABRE-SDB.
BSP: IMX6_M6.0.1_2.1.0_ANDROID_SOURCE_BSP (REV M6.0.1_2.1.0)
We want to use mmdc command.
However, we cannot use mmdc command.
The following error occurs.
root@sabresd_6dq:/ # mmdc
Could not open /dev/mem
Would you tell me the method using mmdc command on Android M6.0?
May I have advice?
Yuuki
So, does it work finally?
Artur
Dear Artur-san,
Yes, it worked without a problem.
Yuuki
I'm sorry.
We noticed that we did not make config of kernel Enable.
A problem was settled by making config of kernel Enable.
Yuuki
