externen Verweis (keine lib), missing binary operator
software_entwic
English:
I use an external reference to a global data in my project collection (no lib). If I want to use a #define in a #if a == x (external define) an error missing comes binary operator. What can I do about it?
Deutscher Orginaltext:
Ich benutze in meinem Projekt einen externen Verweis auf eine globale Daten Sammlung(keine lib).
Wenn ich eine #define benutzen möchte in einem
#if (a == x(externer define))
kommt ein Fehler Missing binary Operator.
Was kann ich dagegen tun?
Labels (3)
software_entwic
In the same file it works, but I must used an external File who it is implemented. By the external reference LPCXpresso make this error, and I don't know why.
this file is one of the first includes, after the system (<string.h> ...) libs.
1) system libs
2) data types
3) this file
4) other def
But I look again the order of this includes.
Andreas Kullick
software_entwic
the construction:
Andreas Kullick
avt
There is no problem with what you are trying to do. For example, this (all in a single file) works as you would expect:
#define _ON 1
#define MY_VAR _ON
#if MY_VAR == _ON
#warning ON
#else
#warning OFF
#endif
So, I can only assume that you have something wrong with your #includes. In your diagram above, does your "Using" box know about the "Predefined" box above it?
avt
C (and C++) pre-processor comparisons only works on integers, not strings. Maybe you could explain what you are trying to achieve?
Carlos_Mendoza
Hi Andreas,
The preprocessor does not know anything about types in the language, so it cannot cast the macro _ON inside the if expression. The `#if' directive will carry out all calculations in the widest integer type known to the compiler; on most machines supported by GCC this is 64 bits.
Could you give us more information on what you are trying to achieve?
Hope it helps!
Carlos Mendoza
Technical Support Engineer
