Processor Expert Programming
uditdhawan
hi people...
i am using codewarrior v4.6 for  HC12
i have developed the programs in C for my project....i wanted to know if i can use assembly along with processor expert cause i feel more comfortable with assembly
ProcessorExpert
Senior Contributor III
Processor Expert does not support generating assembly code for HCS12(X) derivatives. However there is the possibility to use the own assembly code in C project.
More detailed information about mixing the assembly code with C can be found in chapter 11 on page 501 in the Compiler_HC12.pdf file in .../{CodeWarrior}/Help/Pdf/Compiler_HC12.pdf.
best regards
Vojtech Filip
Processor Expert Support Team
UNIS
www.processorexpert.com
